ARGOMENTO: Cavo diagnosi OBD2 e visualizzazione valori
Re: Cavo diagnosi OBD2 e visualizzazione valori 23/07/2012 11:22 #193014
se non ti fa vedere niente forse non funziona nemmeno il tuo o forse è una questione di non compatibilità con le fofi.
Anche io riesco a collegarmi con il bluetooth solo che non mi passa nessun dato...
Il venditore mi dice che lo aveva già testato e funzionava....
  • evald80
  • Avatar di evald80
Re: Cavo diagnosi OBD2 e visualizzazione valori 23/07/2012 13:17 #193045
Allora, io ho risolto seguendo la seguente procedura:
These instructions are written specifically from Windows 7, if you are using a different Windows Operating System, the steps you need to take should be similar.
Open the Device Manager control panel
Find the COM & LPT menu and right click on the item titled ‘Standard Serial over Bluetooth link’ and select Uninstall. If there are two items, uninstall each of them.
From the Bluetooth control panel, also remove the OBD-II adapter from there, right-click and remove the device.
Start your vehicle, plug in the adapter and click to ‘Add a Device’ in the Bluetooth menu. It will come up and you can enter the pairing code.
Let everything re-install from scratch, it might take a minute or two for the adapter to finally show up in the device manager under the COM & LPT menu. You can have that open during the entire installation to watch its progress.
If the COM-Port was set 4 or similar before, it should install to the same COM-Port. We suggest using any COM 2-5. This can be changed from the properties menu.
Open easy EasyOBD-II (this can be downloaded from our website) and connect to the COM-Port. The device at this point will begin to identify your scanner hardware and you are ready to ‘Go Online’ with your vehicle.If you changed the COM-Port during this process and EasyOBD-II is unable to connect to your diagnostic scanner, we suggest to conduct the reinstallation a second time starting from step one.
  • evald80
  • Avatar di evald80
Re: Cavo diagnosi OBD2 e visualizzazione valori 23/07/2012 17:37 #193064
Quindi adesso funziona bene? Io la userei con torque sul telefonino, ma non va :(
Re: Cavo diagnosi OBD2 e visualizzazione valori 23/07/2012 17:38 #193065
Si funziona bene ma io ho provato con ScanMaster-ELM(che è un programma per windows) e non con l'applicazione per android.
Proverò e ti faccio sapere...
  • evald80
  • Avatar di evald80
Ultima modifica: 23/07/2012 17:38 da evald80.
Re: Cavo diagnosi OBD2 e visualizzazione valori 23/07/2012 17:43 #193067
Ok...grazie :)
Re: Cavo diagnosi OBD2 e visualizzazione valori 25/07/2012 14:44 #193284
Con l'applicazione android non funziona nemmeno a me...:(
  • evald80
  • Avatar di evald80
Re: Cavo diagnosi OBD2 e visualizzazione valori 25/07/2012 16:52 #193293
Peccato :(
Re:Cavo diagnosi OBD2 e visualizzazione valori 31/07/2012 17:50 #193881
ciao... potrei vedere una foto?
R: Cavo diagnosi OBD2 e visualizzazione valori 31/07/2012 18:24 #193896
Di che cosa scusa?
Re: Cavo diagnosi OBD2 e visualizzazione valori 28/08/2012 21:55 #197593
Salve, io sto cercando di collegarmi alla fiesta di mia moglie, una MK5 1.2 del 2000, utilizzando il cavo che uso normalmente per la mia Alfa, ma purtroppo senza successo...
Ho provato con ScanMaster, ScantoolNet, PCMScan, OBD2007... ma non c'è verso di accedere alla centralina.
Il cavo in mio possesso è questo. Dovrebbe essere anche compatibile con il gruppo VAG, e funziona perfettamente sull'Alfa.
Ho provato con gli switch in ogni posizione, ma non cambia nulla.
Avete per caso qualche suggerimento da darmi (oppure potete dirmi di rassegnarmi)?
  • Cracker
  • Avatar di Cracker
L'auto di mia moglie: Ford Fiesta Mk5 1.2 16v Zetec GPL
La mia: Alfa Romeo 156 SW 1.8 TS 16V
Tempo creazione pagina: 0.117 secondi
Tu sei qui: Home Forum Nuova Fiesta 2008 - Componenti Elettronica Cavo diagnosi OBD2 e visualizzazione valori
